mine is that we the options for that center area has some crappy options. i saw where the 2022 Bronco (maybe '23 raptor bronco) has a cool "gauges" display you can use. it shows engine and trans temps, boost, oil pressure. but i have to use the damn off road status one because i hate being reminded of how bad my gas mileage and economy stats are!
You can get Tremor to show boost etc..
yes, but this was a cluster of gauges you could get instead of the options you get for the center of the cluster. kinda like the stupid acceleration, braking, speed display with the green lines showing the level of each. i cannot find which video i saw it on, but i believe it was in one of the bronco videos on youtube.
They said the bronco could record and overlay telemetry data too to be fair..
Hmmm mine isn't visible and I have the 2k.
Looked at it again from different view. Was folded under and not seated, simple fix pulled it out. Thanks for pictures and help.
Biggest one for me so far is driver side seat belt getting stuck between the seat and the body column. Ordered some pins off of Amazon to pin it 3 - 4 inches higher than current resting point.
Mind sharing what these are?
New pet peeve here. Homelink always being hot instead of only working when the truck is running. I park in the driveway and was looking forward to having a garage door opener. Since it works even if someone breaks my window out and doesn’t have a key I decided to remove the programming.
On my 401a I have a few issues, I have approximately 2,000 miles so I need to schedule a visit to the dealer soon. I have a Speaker rattle in the right front door from bass, left front door is OK but I heard a rattling there while going over some rough roads. Some rattling in the rear area of the car lift jack. Wish the rake wasn’t as bad, would have liked a 2” front factory lift instead of 1.5” over the regular F150. I’m very happy with the stock suspension, I’m afraid of changing the factory ride. I’m likely going to wait a long time until a Tremor specific 2” - 2.5” max Fox, Icon or King comes out, something that improves greatly over stock suspension but still has that pillow float the Raptor has.
We’re you able to get that front passenger door rattle resolved? I have the same and it’s driving me insane!
Good to know, I programmed my Homelink to my Retrax power cover.
The center console shifter is my biggest complaint. Gimmicky, takes away from storage, prefer a column shifter. No 5.0 option, personal preference.
Mine is that the Adaptive Cruise Control reverts to the speed limit whenever the speed limit changes. Also Blue cruise yellign at me to put my hand on the wheel. It is on the wheel, Def Leppard's drummer would not be able to use the feature.
You can turn the speed limit recognition off if you want, and hand on the wheel can be countered, although I wouldn't do it for a long time.
Why is telling you to put your hands on the wheel? Blue Cruise yells to keep your eyes forward, not your hands on the wheel.
Not sure. but if I don't have two hands on the top part of the wheel (it doesn't even like if I have both down on the bottom) it starts beeping and telling me to put my hands on the wheel. If I don't it turns off.
My lane assist does this if I take my hands off the wheel, although I've found even just giving the wheel the smallest input will get rid of the alert.
My lane assist does this if I take my hands off the wheel, although I've found even just giving the wheel the smallest imput will get rid of the alert.
That's what I do when it's on blue cruise lite. I just nudge it slightly every 45 seconds or when the alert comes on. You don't actually need to keep your hands on the wheel to make the alert go away.
