I must be missing something here. When I pull on the door handle, the mirrors fold out and are fully open by the time I get into the truck.
The forscan for the Lincoln style changes when they fold out.
Got it. I wanted to have the dealer do that and the reverse tilt down when I had a Raptor. They wouldn't touch forscan. They said if the tech made a mistake and caused other issues, Ford wouldn't back them up and they would be liable for any problems.
Sometimes when I start my truck while the mirrors are folding out (i have the Lincoln fold on), they will stop when I press the engine start. Sometimes they continue through the button push.
Drives me crazy, then i have to close and open the mirrors with the button on the door.
Anyone else?
My mirrors automatically unfold with no issue
I need to check if my '23 unfolds automatically. Nomad does this happen when you start the truck, or put in gear?
Also someone else mentioned and I had the experience today....the turning radius is rather horrible on these things. - Rob
I'm pretty sure there is a setting to choose if you want them to fold and unfold automatically. At least on the 402a package.
There is, and then you can forscan “Lincoln “ mirror fold/unfold. That’s seems to be where the issue is.
Confirmed vehicle settings. Just had to poke around a bit....guess I should fully scan thru them all now. Had the truck for 3 weeks! - Rob
This explains the difference between the mode you can set in your vehicle settings and the Lincoln mode you can set using forscan, they are 2 separate things.
I gotta play around myself... had my truck for 4 weeks, just figured out that you have to hit a button on the steering wheel to turn on lane assist... still can't find brake assist... this is my first brand new vehicle, and it has ALOT of technology that I'm unaware of ! Lol
Ford has articles on the tech as well as tutorial videos that walk you through all the factory settings, when you then add forscan to the equation you open up a lot of things that Ford doesn't give you access to through the vehicle settings.
Pet peeve #456, when I get weird random messages on my Ford Pass App like this.... apparently my tremor is now a plug in? :ROFLMAO: :LOL:
Maybe they're telling you that you should've gotten a
Lightening or maybe they're doing one in a
Tremor package.
Not really a pet peeve, but over the weekend I got in my truck one morning and my nav screen wasn't how I normally have it. I have mine on Dark always, and it was on Light so that was my first indicator. Then I started checking things out and most of all my other settings on there (like cruise control tolerance, speed indicator, etc) were back to default. I suppose it's possible maybe it didn't recognize my profile for some reason? I don't know I didn't think much of it, put everything back to how I had it, and it hasn't done it since but since I put everything back to how I had it I wasn't able to see if it was a problem with loading my profile or not. I never thought to check the profile.
I had that problem about two weeks ago no issues since. it was annoying to figure out what reset. i figured it was a profile issue but couldn't really prove that since it was mostly driver settings/features. I am leaning toward just some sort of bug or loss of memory because i've had nothing wrong otherwise with my profile/phone/key.
The range, vehicle would never get warm enough inside. It would feel like you are driving a giant marshmallow, going around a simple corner was like riding a playground ride.
A co-workers father-in-law has one and the range is not all that great, I know he gets less than 300 miles on a charge.
