- Dec 7, 2021
- 1,592
- 2,036
- Charlotte, NC
- 2022 Tremor 402A
- Current Ride #2
- 2022 4Runner Offroad Premium
Subbed for updates
Kinda crazy - you'd think they could easily add a sticker stating allowable tow rating (or even GCVWR) specific to each build since they can do it for GVWR. I'll ramble on a bit in lieu of more substantive info.On other brands, the gcvwr is clearly stated. So gcvwr-gvwr=tow capacity.
So far, I haven't seen anything on the truck that shows gcvwr or real tow rating
I'll grab a picture of my rear spring number. As I remember it though, the springs all show the same number.Kinda crazy - you'd think they could easily add a sticker stating allowable tow rating (or even GCVWR) specific to each build since they can do it for GVWR. I'll ramble on a bit in lieu of more substantive info.
A couple of the major factors that go into a tow rating are: engine output, transmission configuration, tires, brakes, rear differential size and ratio, and the weight of the tow vehicle. ALL Tremors receive the same engine, transmission, tires, brakes, rear differential size and ratio and are relatively similar in weight. So, the major components are the same. It seems the questionable changes might be related to radiator capacity, transmission cooler capacity, perhaps engine oil cooler. I understand how each of those things affect a truck's ability to manage the stresses of towing, but at least they are readily observable and manageable things. IF some of us end up with smaller coolers and it gets hot when really pushing it, just slow down a bit and let 'er cool. It's not as big of a safety issue as say inferior brakes, less than adequate power, etc. Those are all the same regardless across the Termor trim.
I did not mention rear suspension. I'd love to know the answer to whether or not these Tremors are being shipped with different spring packs based on whether they have the Trailer Tow Package or the Tow Technology Package or nothing. That also could affect tow capacity certainly. But, this is a fairly simple / easy change via a new leaf pack or additional air bags. I'm considering airbags regardless to manage any squat when loaded. I love the ability to dial in rear end height and stiffness.
It's dumb that this is even a thing and that we are all having this conversation. The truck should be equipped with it and not an option.Goodness! It should not be this confusing for customers. 401a on order here, with only the Tow Technology package because the all the above info wasn't easily findable. It's interesting the door jamb sticker doesn't specify the tow rating. It specifies GVWR - weight of vehicle plus cargo/people on board. This is DIFFERENT from the max trailer rating.
Compelling evidence has been presented to suggest to get the 10,900, you have to get the trailer tow package (not just tow tech). But, it's frustrating there's no clear difference. I tow infrequently and would love a presumed more compliant ride day to day. But I also like the idea of being able to comfortably tow 8K or 9K from time to time.
I hate to ask the dealer because they don't understand this near as well as most on this forum so I can't trust them.
Where on the truck will it actually state the allowable trailer tow rating?
Tremors don't have a "max trailer tow package" option. The only option on the Tremor is the "trailer tow package".View attachment 874
I don't see an asterisk by Tremor
Welcome! I ordered one day ahead of you haha. Did you order from Granger?First post here, I ordered my 401A Tremor last week on 12/23. I didn't know this was a topic of discussion until after I placed my order. I've been researching this over the last few days now and this is what I've found...(more confusion!)
-Ford fleet guide for '22 says Tremor is rated at 10,900 lbs.
-Ford fleet guide also states not to tow more than 7,000 lbs without trailer tow package
-Ford website lists specs for Tremor at 10,900 lbs
-Building a '21 or '22 Tremor on Costco Auto shows the Trailer Tow Package: "includes towing capacity up to 'TBD' pounds."
-Tremor "Hero" Card shows towing capacity of 10,900 lbs but the annotation says "requires trailer tow package"
-Ford B&P says nothing about increased towing capacity with trailer tow package.
I feel this misinformation is a bit ridiculous so I called Ford twice. I used a new car website to get vin #'s for a 21' 400A and a '22 401A, both without any tow packages. I gave Ford the vins and asked "How much can I tow with my new truck?" In both instances the rep came back and said 10,900 pounds.
I'm not taking this as the definitive answer but I thought it was worth sharing.
Thanks! I went with Chapman, they're much closer than Granger is for me.Welcome! I ordered one day ahead of you haha. Did you order from Granger?
Do you know where he got the 7,100 lb figure from?So I just spent 45 minutes at my dealership trying to figure it out. The equipment manager or whatever his role is was adamant it shouldn’t make a difference. I made him pull up the ordering site and we compared the difference. Even though the trailer tow package is $200 more, you still have to also add on the 360 cameras for another $750 vs. the tech package which includes it. When we dug into the details, the trailer tow mentions an axle difference in the back and tow tech does not. Fortunately, I was still able to add trailer tow and delete trailer tech. A guy in the tremor Facebook group also said his only tows 7100 with the the package. I would have been pretty upset if it got here and towed 4K less lbs..
The F350 tremor has the larger rear axle. As I remember it, it also has a different load spring in the pack.I don't know if this has merit or not but before I bought the 21 F150 tremor I had a 350 XLT tremor and 250 Lariat Tremor. You may already know this but the 250 and 350 Tremors have the exact same suspension, springs, axle and all other parts. There is zero difference between the 2. Ford just de-rates the 250 for whatever reason. My guess is they do same here.
I have the 401a with tow package and 360 camera and have the 10,900lb towing capacity. My guess is if someone wanted to spend the time and look at the part numbers for the 400 and 402 we might find the same as with the super duties.
Not on the tremor. Same part numberThe F350 tremor has the larger rear axle. As I remember it, it also has a different load spring in the pack.
Not on the tremor. Same part number it's been debuged several timesThe F350 tremor has the larger rear axle. As I remember it, it also has a different load spring in the pack.
The f350 has a 4" axle tube and about 1000 pounds more capacity unless you get the 10k derating. The f250 has the 3.5" axle tubes. It's been that way for at least 10 years when the new axles came out.Not on the tremor. Same part number it's been debuged several times
I’d like to know (seriously) how you know you have the 10,900 tow capacity. I’d also like to know how the guy mentioned above knows he has the 7,100lb capacity.I have the 401a with tow package and 360 camera and have the 10,900lb towing capacity.
I 100% agree. They all have same wheelbase, engine, brakes, suspension, trans, and axel ratio. That's all that matters for tow capacity. The whole point of the tremor is to be off-road capable, yet still be able to tow/haul. Of course they will still let you add on the fancy gizmos to make towing easier, but it doesn't affect the tow capacity.I’d like to know (seriously) how you know you have the 10,900 tow capacity. I’d also like to know how the guy mentioned above knows he has the 7,100lb capacity.
They’re not putting a sticker on the truck stating as such, right?
I’m tempted to think all Tremors have the 10,900 capacity. There’s so much that’s standardized in the ‘hardware’ department - body style, drivetrain, engine, trans, differential ratio.
