I'd say my front end sounds the same as in this video just from listening from the inside of the truck. Mine makes noise whether turning or going straight. But i've triple and quadrupel checked everything and I cannot find the source or make it go away.
I'm just living with it for now, but it sounds like crap but I can't tell it is actually damaging anything.
I sent Kevin at Halo a message but I wanted to ask the group also. I have my truck back at the installer to check everything out. I'm getting noise on the right side when turning and hitting some small bumps like in the video. Turning left is solid no issues. You can hear it pretty clearly in the cab and I stepped out to video and it's very noticeable. Every thing appears to be tight, they did have the camber kit washer not fully seated so I had them fix that and it's still making the noise. Any ideas?
Link to vids: Right side makes noise, left side is solid
This is now flush
Both sides? Has to be something since my driver side is perfect. Feels solid and quiet. We've double checked everything also and can't tell anything is wrong. I've emailed Kevin at halo for his input.
Are the codes from this first page still active, thinking I’m going to go ahead and order the kit.
Watch the video posted that tremor trails did, he gives a code on it that should work, or read back a page or so I think they posted another code.
I just realized I asked the wrong question. Should I say do the codes still stack or can we use both codes at the same time for the 10% and free shipping? Seems like only the 10% off works. Just trying to maximize my savings lol.
Can someone give me a measurement to the highest point on the truck with the halolift and 285/75r18 tires and maybe 295/70r18??? I don't drive much and want to fit in my garage I think I have enough height to clear, but I'm getting nervous and I really want to order. Thanks
As you know the coilovers are adjustable. I'd suggest you measure YOUR truck at the highest point then compare to the lowest point on your garage. If the difference is less than 3" you are probably SOL. For me the highest point (402A) is the two bumps on the back of the cab (Sat. radio and modem). My Halos are set on the lowest setting so I gained roughly 1.75" there then another +/-1" from the 285/75R18s. But lets round up and say I gained 3", that translates to about 1.5ish higher at the antennas. Rear will actually pivot down slightly if you don't change blocks.
Point is, lot's of approximations and roughly's above, don't rely on some guy on the internet with a tape measure to make sure you have clearance in your specific garage.
Hello There,
Please send us an email regarding your issue you are having and we would be happy to take care of you. Please include any videos and or pictures. You are welcome to email us at [email protected].
Please let me know if you have any questions,
Thanks,
Kevin
Hello there,
You are welcome to use tremor10 at checkout to receive 10% off your order. Unfortunately you Can't stack coupons but 10% off will save you more money than free shipping.
Please let us know if you have any other questions!
Thanks,
Kevin
Hello there,
How tall is your garage door? I park my Tremor in our garage at our house and we have a 7 foot garage door. If you have a 7 foot garage door then you can easily park it in your garage.
Please let me know if you have any other questions!
Thanks,
Kevin
Hello There,
Thanks,
Kevin
Elka is sending me a set of new coilovers that i'll have my shop install and see if my passenger side noise goes away. I'll be the tester and report back in 1-2 weeks.
Hi Kevin, do you happen to know how much travel the 2.0 coilovers provide, I’m thinking maybe 5.5 thanks
Hello there,
I'm not sure to tell you the truth. Let me see if I can find that out for you.
Hello there,
Thanks,
Kevin
It’s a touch over 7’ thank you
Any more group buys planned on the Halo kit?
Might be worth checking out, be curious as to how much actual lift you get and the ride quality, they also have Elka products on their site so they may be made by Elka. If so Elka has some top notch stuff for offroad.
I just installed the 2.0 and their UCA a few days ago, I had a standard 2.5 level kit on my truck previous, it measured 41.75 from ground to lip on front fender, with the halo kit I gained another .75 of an inch…up to 42.5 inches and that’s with their 2.5 inch standard spring length as delivered.
I’m going to drop it down at least a 1/2 inch.
This is with 305/70/18 bfg on oem wheels
Nice, is the ride any better?
Hello There!
You are welcome to use Tremor10 at checkout to receive 10% off your order. Please let me know if you have any questions!
